Hello everyone,
I have a Macintosh Portable, backlit M5126 model. When I first purchased the unit, I utilized a new 6.4 v 4.5ah battery to replace the old dead main battery. Furthermore, I replaced the 9v secondary battery. I tried powering the unit up, and it did nothing. Upon a first disassembly I located numerous bulged/leaking caps, the board overall was dirty as well. I removed all SMD/through hole caps, I then washed the PCB, and baked out all of the moisture in the oven (170-185F, for 20-25 minutes). Upon confirming that the PCB was dry, I recapped the entire PCB. Once I conclude the recap, I reassembled the computer and attempted to boot after holding the reset & interrupt switches. Upon trying to boot, again, it did NOTHING, no chime, no HDD noise, nothing. It was as if the board wasn't getting power, it also wouldn't display anything on the screen.
There was some surface crud that gathered on top of several traces. I've tested all questionable looking traces, and each one does in fact have continuity. I previously inquired on this forum as to what I could look for, and I was informed that it could be bad traces/connections near the reset/interrupt buttons. I checked everything and nothing appears out of order. I've tried to find schematics for the M5126 model, but I've been unsuccessful in my attempts. For clarification, after cleaning the board, I've noticed some residual grime that has stayed on the surface, I need to find a sure fire method for cleaning PCB's.
I guess this post is just me reaching out to anyone that has any input on the matter, or could offer guidance. I'm new to restoring computers, I'm accustomed to cleaning/maintaining game consoles, which I've amassed a collection of.
Thanks everyone,
Gary.
Thanks everyone,
Gary.
