Mac Plus reflow success - looking to SE next
Mu0n
My childhood Mac Plus (2.5 mb) from 1986 was recapped back in 2019 as I was re-learning soldering and wanted to future proof my collection. I was maybe too enthusiastic with the electrolytic + RIFA ones on the analog board and ended up replacing them all for good measure - it's hard knowing how to reach a balance between a fear of missing out and just confidently reacting to problems as they arise. I digress.
Fast forward to a couple weeks ago, powering up the ol' Plus to test out my defunct external hypedrive FX/20 hard drive, the screen suddenly collapsed to only showing the 3 left-most pixel columns, none of the rest.
I finally had some time to investigate the issue this week and found some textbook usual suspects, solder joint cracks in the J connectors of the analog board mostly, and some that looked suspicious in the J power connector of the logic board.
This was the worst looking one under my cheapo usb microscope (that I like to call macroscope):
I love it when the most common issue is easy to identify, easy to deal with and put behind me:
BONUS: I beat the CPU right away on this playthrough of Archon, with a teleported unicorn sent on a basilisk-less side near the sorceress, and the unicorn then took her down.
NEXT PROJECT: deal with the wobbly screen that I've seen most Mac SEs suffer from - are we looking at a similar solution (I'll of course check them out and probably do them) or a diode that needs replacing? I think my Mac SE/30 also does it, but more rarely. I'll test the solution on the SE first as I'm less attached to it.
joshc
Bad capacitors, weak solder joints and possibly other component failure are the possible causes of that. I'd tackle the easy stuff first just like you did with your Plus, reflow the yoke connector to see if it helps first.
