ecliptik
New member
I have a Macintosh 512ke that I've been working on over the last 6 months and have really enjoyed it. As I've gotten more ambitious I've started bumping into it's limitations and want to take it to the next level. Earlier this week I came across a reasonably priced Mac Plus board with 4MiB of memory and it will be here within the week.
My understanding is the Mac Plus logic board is a drop-in-replacement for the 512ke and it should just work when hooked up. However due to the different port configuration, the old 512ke case back won't fit. After searching and reading forums I've come up with the following options.
1. Cut out the port part of the case so it fits both 512ke and Mac Plus logic boards
2. Buy a Mac Plus case back from Ebay or somewhere else
3. 3D Print a case back
I am avoiding option one since it's destructive and can't bring myself to do it.
Searching Ebay I found a few bare cases, but they're all extremely expensive after shipping and at that point I might as well buy a complete Mac Plus. I was hoping that there were after-market cases like MacEffects, but those only target SE models.
The third option seems best, especially after I found The Brewintosh [1] which is a 1:1 3d printable Mac Plus case. My assumption is that I can print just the back portions of the case, cutout/remove the ports and use it with the Mac Plus logic board. This also has the benefit of customization, printing it in different colors; and if the results are good maybe send it off to a 3d printshop and get a print in higher quality material (maybe transparent or tinted resin ala MacEffects).
Has anyone else had a similar experience with upgrading a 512/128 and getting a case or any thoughts about how to do this effectively? Anyone else 3d printed replacement cases?
Ironically during my searches I kept coming across posts how this was a common upgrade done in the 80s, so it's not unheard of, but doesn't see as common as it once was.
1.
1.
