Mac Plus analog board shield pins?
Spacerog
I am sure this is answered somewhere but i don;t even know what they are called to search for them.
What are the little black pins that hold the plastic shield to the side of the Mac Plus analog board? I have a 1986 board that uses the doubled sided tape which has completely deteriorated at this point and would like to clean off the tape and use the pins instead. Where do I find those? What do I search for?
Spacerog
I received the ones from Granger linked above, they are about 2mm longer than the original but work fine. If I order them again I will try one of the other sources.
