glay78
Ok long story short, I connected the battery in wrong polarity, after I found out I was wrong I switched back.
The portable still powers up but unable to run scsi HDD nor charge the battery. I think one mosfet could be blew but I’m not sure which. When I plugged in adapter and battery, voltage tested at battery point was 6.33v. If I do this on a working M5120 it reads 6.9v so I’m presuming the power couldn’t charge the battery hence not giving enough power to run the scsi HDD too.
Can anyone enlighten me which mosfet or which component is affected?
