JAG
I don't know why this isn't working, so I'm looking for some advice on where to start.
I have a linux based netatalk server that runs perfectly well serving up files via ethernet, even to an old SE/30 with an Asante ethernet card.
I'm trying to hook up a Mac Plus and SE to the netatalk server via a Localtalk to Ethernet adapter.
Initially I tried an AsanteTalk and it worked once and then quit working. It still powers on, but no amount of fiddling with startup sequence etc get it to connect.
I then bought an Apple Stylewriter Localtalk to Ethernet bridge on eBay and it also doesn't work (it looks like a Farallon iPrint, but is beige)
I then bought a Farallon iPrint on eBay and it also fails to connect.
So, two things occur to me: either my netatalk server isn't setup correctly (though it works flawlessly with devices via Ethernet and worked once with the Asante) or the bridges I'm using are flaky, though what are the chances that three of the them would all not work?
Any suggestions?
Any suggestions?
