sunder
LisaEm 1.2.0 is available for download right now, from the usual place: http://lisaem.sunder.net/downloads.html
Many LisaEm users have complained that ROMs are too difficult to extract. The new version of LisaEm solves this by allowing you to run with out a ROM. If you wanted to try LisaEm, but couldn't because you didn't have ROMs for it, now you can!
LisaEm emulates the functions of the Lisa Boot ROM as well as the Dual Parallel Card without requiring a ROM, and allows you to boot into Lisa Office System. If you've felt limited by only having a single emulated Profile hard drive because you didn't have the Dual Parallel ROM, the new version also emulates these, without requiring a ROM.
All you need is Lisa Office System and LisaEm.
As this is the first release of this feature, don't be surprised if you encounter bugs. Please report any unexpected behavior so that I can fix it.
Additionally, I've added two movies that show how to install Lisa Office System and MacWorks. (MacWorks still doesn't work properly on LisaEm however.)
If you'd like to support this project, you can do so by sending me something from my Amazon wish list. (Used books and DVD's are perfectly fine with me.) The trains are for my kid. http://www.amazon.com/gp/registry/wishlist/14EOBF86ARMDT/ref=wl_web/
Code:
Lisa Emulator Change History http://lisaem.sunder.net/
2007.09.19 - fixed romless floppy boot to always boot from floppy and not
switch to Profile.
2007.09.15 - debugging ROMless boot.
new bug: when trying to boot from floppy, if a profile exists
and is bootable, LOS starts up from the Profile instead of the
floppy.
2007.09.09 - David Cecchin's XPM icon in unix
2007.09.07 - added Save/Load PRAM to Preferences
- Quit now closes any open Preference window as well
2007.08.29 - libdc42 macbinii encoded dart to dc42 conversion bugfix
2007.08.16 - added LOS error codes to ROMless error handler
- fix raw screenshot crash
2007.08.13 - got both ROMless boot and ROMless dual parallel card to work
2007.08.06 - individual profile power controls + create new profile inside
a new menu named profile.
2007.07.28 - replaced all exit() and EXIT() calls with messages before
quitting emulator so at least we know what crashed.
2007.07.27 - ROMless works with both profile and floppy now.
- Fixed a bug with configuration saving.
2007.07.26 - Tracelog checkmark correction
2007.07.25 - added Zap PRAM button in main Preferences panel
2007.07.23 - ROMLess booting - floppy works
2007.07.19 - ROMLess booting start
2007.07.12 - RESET opcode supervisor mode bug fix.
2007.07.10 - CPU core tests
