elemenoh
I have two 512k memory boards. Both pass the startup test in either slot on their own and they also work when installed together in either slot.
The device can boot Mac Works or Lisa Office boot disks, but won't boot any diagnostic (either images via FloppyEmu or actual disks).
The following all have the same results:
LisaTest 2.2
LisaTest 3.0
Lisa 2 System Diagnostic
Lisa Burn In Diagnostic
They load the various boot files but hang within a second or so after actually beginning to boot.
When it hangs, the disk drive stops making noise. If using FloppyEmu it shows as idle. The Lisa will just hang on the screen with an hour glass. Verbose mode just shows 'Booting..." as in the screen below.
When booted with Mac Works, 'About The Finder' shows 512k whether one or both boards are installed. But as mentioned before both pass the startup test in either slot on their own or as pair.
So, is this a known issue? I'm kind of at a loss for what to try. I'd like to get diags working so I can thoroughly check this recently restored Lisa for full functionality.
Thanks!
LisaTest 2.2
LisaTest 3.0
Thanks!
