LC475 no video output, suddenly
Plasticoat
Hi,
yesterday my 475 froze midway through boot process, since then, I’m unable to get any video output.
the bong is strong at startup, however the
converter to vga does not process a signal
to turn on my monitor.
the battery is fine, however I’m stumped,
any ideas please, thanks in advance
Challenger 1983
If you have already recapped the machine try cleaning the board again as sometimes cap goo can get underneath chips and components
Plasticoat
Hi again, this LC is fighting all the way !
i cannot reset the pram now, and I’m wondering if it’s become corrupted?
is there any tricks to resetting, the keyboard just is not working. Command option and p, r
on restart, no reply from board.
so I’m left with a 475 that does nothing other than bong.
thanks again
MrFahrenheit
The 475 should have a red on board button to reset in case of corruption.
Unplugged, with no battery installed, press and hold down button for 10 full seconds. Wait a minute. Install battery. Wait a minute. Power up.
register
Is the VRAM properly seated? It is possible to start a LC 475 with no VRAM installed, resulting in black 1-pixel graphics output. You get a black pixel in a screenshot that was created in such a setup. One possible use is a headless machine that is used as a print server or file server, resulting in a minimum of graphics processing.
