I made this myself - quickly - and it may have errors. There are some caps not called out here - specifically under the shielding and behind the flyback, but I've never seen these caps fail. And, usually, I only replace the larger ones 100uf and larger (squared in red).
Comments:
1. One of the 3300uf 16v is a low-profile/pancake form-factor, but I've used a normal height cap there without issue.
2. I typically replace all similar value capacitors (1000uf for example) with the highest voltage needed (25v for example) instead of buying a 25v, 16v, and 10v.
Good luck to you.
