Large volumes in a 68030
kissmyash933
So, I recapped my IIci and stuffed it full of cards only to find out that the HDD was dead. My standard method of replacement is a 2.5" IBM Ultra 320 SCSI drive on an adapter, partitioned into small chunks. I booted up the machine, formatted with a Patched Drive Setup and installed System 7.1 only to find that it wouldn't boot, and then wouldn't mount when I booted up with a DT disk. The error received was "You need a 68040 or PPC mac for large volumes" I was under the impression that as long as I kept the partitions under 2GB, everything should work fine. Any way around this particular issue?
johnklos
You most likely need to use Apple HD SC Setup (patched) or an older Drive Setup. I always thought Drive Setup would DTRT when running on an '030, but I suppose not. If I had to guess, I'd guess you have a Drive Setup from 8.0 or 8.1.
Somewhere there's a list of versions of Drive Setup, the versions of SCSI drivers they install, and what models of machine are supported by each version, but I don't know where that is off the top of my head.
Unknown_K
Pretty much what pcamen posted. You used a formatter for PPC and the 68k machine didn't like it.
JT737
I use Lido 7 to partition my drives.  In my SE/30 I am currently using a SCSI2SD converter with a 16gb micro SD card that I have partitioned into 4 4gb slices.  Works great!   And it sure is nice to have the space.
kissmyash933
Thanks!  Not sure why I haven't heard of the adapter/2.5" ultra320 combo before but I'm glad I just did.  $32 shipped for both is what I paid.
The adapters quoted are the exact adapters that I use. It seems they have gone up a little bit in price though! They work like a charm, just make sure you have a terminator on the end of your cable since these drives don't do internal termination.
ScutBoy
I've used these as well with surplus 2.5" SCA server drives. The drives can get a little warm but since they are 2.5" in spaces generally made for 3.5" or bigger drives, "stock" ventilation is usually enough.
I use in-line terminators at the board (cable->terminator->board->SCA drive) and this seems to work fine.
badCaps
Got my adapter, the same as linked but from different seller, and IBM U320 drive.  Didn't think about the terminators!  Plugged it all in and the drive doesn't even spin up.  No terminator but I don't see how that would prevent the drive from powering up.  I guess my options are buy another drive and or adapter to see which one is the issue, then return the defective item.  Well before that I'll try a different machine and just plug the drive/adapter into an external power supply.  Any other ideas?
kissmyash933
That's weird that it wont spin up, but I have actually had this problem before. Does it spin up if you hook it up to a regular ATX PSU? I've seen some PSU's on macs not provide enough power, and I've also seen sometimes that there is a Motor Delay jumper set, or even a motor jumper that needs to be set to tell the drive to spin up, look at the jumpers on your adapter.
also: these adapters aren't what I would call excellent quality, I've had a few of them fail on me. Check for cold solder joints and buy a couple more of them that actually have the labels next to the jumpers for testing. :)
badCaps
I ended up buying a new SCSI adapter and the drive worked fine.
Not sure what everyone is using for a mounting solution but I couldn't find anything so I made this 3d printed adapter thing.  Adapts to the plastic rail and provides strain relief for the SCSI adapter.  Works good so far in my 6100.
Are these rails pretty universal among PPC chassis?  Looks the same as my 8500, Performa 62xx and a few others.
johnklos
I like the mounting! I just bought a 300 gig 3.5" SCA SCSI drive because I couldn't find a mount for an IBM 2.5" drive. What you have would've likely worked perfectly, but the 300 gig drive was only $25.
ScutBoy
That 3D printed adapter is awesome - I like that it holds the adapter PCB steady. Would you be willing to share the .stl?
MrFahrenheit
Just a warning that not all SCA to 50 pin scsi adapter boards are the same. I struggled for months trying to buy ones that worked with the Mac. At the present time there aren’t any on eBay that will work properly with a Mac.
I found a place that still stocks and sells them. It’s at Datastoragecables.com. You have to make sure your board has 3 rows of terminators on it. Many on eBay say they have termination but when you receive it, it’s not the same as what was pictured. I know because I bought some from pretty much every seller and I have a box of adapter boards that just don’t work.
Ive bought nearly 50 of the boards from the supplier above and they work perfectly.
