sos_nz
To go with my partway restored SE/30, I seem to have picked up some sort of retro mac bug.
Background:
I just picked up a used (obviously!) 1400cs. It's a fairly low spec'd machine - 133, only 16MB RAM, System 7.6.1.
It hasn't been used in a few years, apparently. Battery is totally dead, but runs fine off the AC adapter and boots successfully into the finder.
Problem #1:
It came with a Farallon ethernet PCMIA card - great. Trouble is, no internet. As it was as a student's laptop, it has IE 4.0 on it, and seems to have the correct drivers for the ethernet card. Therefore, I assume it's been internet-capable at some stage.
The TCP/IP control panel allows me to select 'alternate ethernet'. Using DHCP (and opentransport 1.1.1) the green light comes on when the Farallon is connected to my router (Linksys WRT54GL running tomato 1.28 firmware), but it doesn't receive an IP address and doesn't appear in my router's list of connected devices. Appletalk is set to 'inactive'.
Problem #2:
Won't recognise the CD-Drive module. The orange light blinks 4 or 5 times when I insert a disc, but nothing appears on the Finder desktop, and the CD drive isn't even selectable as a startup disc. The drive doesn't eject when pushing 'eject' in Apple CD Player, and it won't boot using the official 'Powerbook 1400' system setup CD that also came with the machine. I don't even hear it spinning the disc (unless it's the quietest CD drive in existence!).
I've reset the PRAM and Power Manager as per these instructions, to no avail. http://support.apple.com/kb/HT1781. The floppy drive module works fine.
Thoughts? Bad CD module or M/B capacitors? Anything else to help diagnose the problem? I'd like to get OS 8.6 onto the machine if possible, but obviously that'll be difficult without the CD drive!
Background:
Problem #1:
Problem #2:
