JetPack for SE/30
IlikeTech
I just had an idea.
If someone can get the IIsi's NuBus adapter working in the SE/30, you could build a thing that goes on the back and holds the adapter as well as a Radius Rocket.  That would be one blisteringly fast SE/30.
Also, you could call it a JetPack for added awesomeness.
IlikeTech
Now we just need someone to make the NuBus adapter work in the SE/30.  What ever happened to that effort?
Trash80toHP_Mini
NIGHT STALKER
The Expanse30 NuBus expansion box for SE/30 used a single cable. Pretty sure it was incompatible with the Rocket and it's way too big for a JetPack to look right anyway. Now NuBus-IN-SE/30  .  .  .
.  .  .  would be an entirely different story. :ph34r:
epooch
The SE/30's 16MHz bus speed is not right for running 10MHz  NuBus. That's why the 20 MHz IIsi can do NuBus with so little hardware. You would probably need to accelerate the SE/30 to 20 MHz, and lose all of its onboard capabilities (including video and SCSI), or have a whole lot of hardware doing timing and caching. Basically another whole computer running NuBus. Maybe some card that are not timing dependent would work, but I can't think of one that wouldn't at least need a crystal change. Then your fast accelerator is running 25% slower, at best.
Trash80toHP_Mini
NIGHT STALKER
NuBus is independent of the processor bus clock. NuBus runs fine at 16MHz, it was introduced in the Macintosh II at that clock. The Rocket runs in IIx/IIcx and even the Mac II with FDHD ROM and PMMU upgrades to bring it up to near IIx spec.
All NuBus requires is the Controller and MUX setup on the processor bus, just three ASICs in the IIsi and anything later.
Interesting side note: discrete PMMU in the Mac II is the full Monty, the on die PMMU of the 68030 is a less capable, bargain basement subset of the 68851.
epooch
NuBus Runs on a 10MHz clock, even on the II. The discussion was about a IIsi NuBus adapter. The Mac II has 4 state machines to keep the system synced up with Nubus. Maybe they are all incorporated into the IIsi NuBus adapter, but I don't see why they would be.
Trash80toHP_Mini
NIGHT STALKER
Vanilla NuBus always runs on a 10MHz clock, it's processor independent. Don't remember that changing for NuBus90. Dunno about state machine involvement, just how the  hardware for NuBus is set up. It's "Controller" + "Transceiver/MUX." In the Mac II of 1987, there are a lot of discrete components involved, later implementations were done in Apple's ASICs that paralleled TI's integrated Controller/2 Transceiver chipset.
Project 30 is all about the IIsi Adapter. Check out the great new info just posted by nickpunt:
Trash80toHP_Mini
NIGHT STALKER
OOPSIE! That was equivocal, should have said "NuBus expanhsion interface or chipset."
I'm usually on the other side of any given page. [;)]
omidimo
I won't take credit of scanning that, but I did upload it to Archive.org to make it easer to read up on it. BUT I will be scanning the RocketShare manual as that is not online.
@techknight If you wanna learn more tech stats here you go:
