Is the 660AV case the same as the 6100?
Unknown_K
Was wondering if the 660av case was the same as a 6100 as in the CDROM bezels are interchangeable.
I recently won a 660av (no idea if it works, not here yet), and was looking into upgrades if I get it working.
EvieSigma
Young ThinkPad Apprentice
CD bezels are interchangeable, yeah. I can get you a bezel and drive, I have a spare from the first 6100 I bought that turned out to be dead.
Unknown_K
The floppy drive is auto inject with the hole for manual eject to the right side, so it would be different then a 6100 that has the manual inject floppy with the eject hole on the bottom.
Is there a separate floppy bezel or is it just part of the lid, I think that only the CDROM bezel comes off. Been a while since I worked on my 6100 machines.
Trash80toHP_Mini
NIGHT STALKER
Yep, one piece with an opening for the CD and blank bezels. I've hacked the one on the ugliest 6100 extant, bought for that very reason on eBay. There's a thread about it somewhere.
Forgot about the power button/floppy eject fiasco. :lol:
Unknown_K
The 660av arrived yesterday. The motherboard needed a recap job which I just finished. Seems like the PS is dead (power light just flickers), stuck in a 6100 PS (same model) and it bongs.
Anybody know how to fix an ASTEC AA16990 Apple part number 614-0022?
The fuse is ok, and after vacuuming out the dust I don't see anything burnt, charred, bulging, or missing. No funky burnt smell either.
