is https://www.macintoshrepository.org/ down?
mraroid
Hi...
Almost a week ago, I tried to go to Macintosh respiratory.  But I forgot my password.  I asked for a password reset and was sent email, a code and a link.  When I tried the link, nothing happened.  I tried several times, and then tried the main web site again.  I got either a time out message, or a refused message.  I moved from a Mac, to a Windows box, and to linux.  Same thing.  So I drove to a WiFi hot spot in my town and tried it.  Same thing.
I am not sure if the site is down, or they have blacklisted me by mistake somehow.    Can anyone get in?
If so, can someone post a help email address for them?  I would like to contact them to fix any issues.  It has been about a year or two since I went to this site.  I usually only hang out here.
Thanks
mraroid
mraroid
OK.  Thanks.  I guess I will have to cross them of my list unless I can contact them somehow.
Appreciate the feedback.
mraroid
Daniël
Most of the Repository's software is ripped straight from Macintosh Garden. If you can access Macintosh Garden, you're really not missing much.
Torbar
I was able to successfully reset my password with it. You may have luck emailing info[at]macintoshrepository.org since thats where the password reset email comes from,  not sure if anyone actually checks that mailbox or not
Alex
Everything you need is on the macintoshgarden with the added bonus of no pay wall nor login crews ever being necessary. Glad you sorted your issue.
mraroid
Thanks everyone.  I do like the MacintoshGarden.  macintoshrepository has been so hard to deal with, that I think I will just pass on trying to contact them.
mraroid
