jkheiser
My rainbow set arrived yesterday and I’ve been playing around with them ever since.
As I mentioned in an earlier post, my Orbi mesh network is unfit for the task, so I set up a dedicated wifi network with an ancient Linksys WRT54G running DD-WRT. I joined a pair of AirTalks to this network and then connected them to a pair of Mac Pluses: one running System 7.0.1 as an AppleShare server, and the other running System 6.0.8 as the client. I also spun up an AppleShare client with System 6.0.8 in Mini vMac (v37.03) on a recent MacBook Pro running Monterey. These were the only three Macintosh devices on this network and they were used to copy the same 676,909-byte file using the Finder.
The 43% drop in performance from wired to wireless is a bit more than other AirTalk users have reported. Maybe 802.11g is a factor? 54 Mbps is slow-ish by today’s standards, but I thought it would be sufficient for AirTalk’s needs. Even so, I’m fairly happy with the effective speed I’m getting. Almost 50 Kbps is not bad.
The big surprise was the abysmal throughput with Mini vMac. I tried a different wifi router (Actiontec C3000A) but had the same performance issues. I cut AirTalk out of the equation and used another MacBook Pro to do a Mini-vMac-to-Mini-vMac copy of the same file, but average speeds remained around 5-15 Kbps. Clearly there is something going wrong with Mini vMac on my end.
Client | Server | Connection | Time | Rate |
System 6.0.8 Mac Plus (real hardware) | System 7.0.1 Mac Plus (real hardware) | Wired | 64 seconds | 84.6 Kbps |
System 6.0.8 Mac Plus (real hardware) | System 7.0.1 Mac Plus (real hardware) | AirTalk-to-AirTalk | 112 seconds | 48.4 Kbps |
System 6.0.8 Mac Plus (Mini vMac v37.03) | System 7.0.1 Mac Plus (real hardware) | Mini-vMac-to-AirTalk | 862 seconds | 6.2 Kbps |
