iMac G3 - Capacitior List?
maceffects
I have a 700mhz iMac G3 that I'm looking to see if a capacitor list exists so that I can order and match capacitors.  Can any direct me to where such a list might exist?
phlogios
I would also be interested in such a capacitor list, I am working on an identical broken 700MHz iMac, however on my machine the logic board is broken, not the analog board.
Iesca
Here is the capacitor list I made for my iMac G3s. They are iMac DV SE (Special Edition) 400 MHz "Graphite" models. While obviously not quite the same, perhaps it can be of some use.
  • iMac G3 DV SE Slotload Graphite 400MHz Electrolytic Capacitor List 2.0.pdf
3lectr1cPPC
Do you think this list would work for the non-dv first gen blueberry slot load model (same except for the 350MHz FireWire-less video out-less board). Mine unfortunately is in need of a recap (ugh) so I should probably get on that soon...
Iesca
My guess is it would be similar, particulalrly for the analogue board, which I would imagine is unlikely to have changed significantly between the 350 and the 400. The only way to know for sure though would be to cross-check your board against the list, but this at least would give you something to start with.
Byrd
Out of interest what caps need the most attention on the iMac - PAV, or analogue board? I've an iMac G3 233Mhz that displays power issues, all caps look OK - there are many ....
3lectr1cPPC
Mine boots fine but the CRT geometry has problems. It is clearly a very high hour tube (the hard drive had some 28 thousand hours on it among other things), but the problem is that whenever I open a window (or whenever anything changes), the image shifts. My guess is that the caps have just been expended up their usable life, not some time related failure.
