bigmessowires
That makes sense, but is probably a little crazier than I'm likely to attempt any time soon. Maybe you want to try it? Those cards are probably just going to gather dust if I hold on to them.
Wait ... you have a working example?I anted up some fairly serious chips on an eBay Card Lot just to get that particular SE'30 version of the card/cable combo
You and me both. This mess is unreadable.after reading through this whole thread, I'm / confused.
Of the IIsi version, several, they all work great with the SE/30 card's cable. The SE/30 card itself is untested, no SE/30 ATM, but it's not really an interesting card anyway, it's basically a full height PDS card with no passthru connector, you can't even install it on top of a NIC.Wait ... you have a working example?
1 RED GND
2 RED
3 C SYNC
4 SENSE[0]
5 GREEN
6 GREEN GND
7 SENSE[1]
8 N.C.
9 BLUE
10 SENSE[2]
11 C & V SYNC GND
12 V SYNC
13 BLUE GND
14 H SYNC GND
15 H SYNC
PIVOT VGA
1,6,13 4,5,6,7,8 VIDEO GND
2 1 RED VIDEO
4,10 NC PINS 4 & 10 JUMPERED TOGETHER ON PIVOT END OF CABLE
5 2 GREEN VIDEO
9 3 BLUE VIDEO
11 11 C & V SYNC GND
12 14 V SYNC
14 10 H SYNC GND
15 13 H SYNC
