Because I'm crazy, I cobbled together a IIsi power supply tester. Probably good to have anyway if I'm planning on designing a replica riser board. It'll help me test and calibrate a new riser board without potentially damaging a motherboard.
I just used a 20-pin ATX extension cable and cut it up to turn it into a 10-pin Molex Mini-Fit Jr breakout cable. To make things easier to look at, I moved the wiring around in the connector so the colors would make sense.
I set up a microcontroller to precisely control /PFW. I don't have anything sitting around that has 5V GPIO and also runs on low enough power to only need the 1 mA that PSTRICL is rated for, so I just used one of my old AVR-based ROM SIMM programmers and powered it over USB for controlling /PFW. I leave /PFW floating most of the time. I can temporarily drive it high for 200 ms to turn the power supply on, or low for 100 ms to turn it off. Those pulse times match the captures I took earlier. BTW, I also added the 3.3k pullup from /PFW to the power supply's 5V rail through a diode just like the IIsi logic board has, for keeping the power supply turned on after the 5V rail comes alive.
I'll eventually find a super-low-power 5V MCU and add that to really finish this thing up and remove the dependency on my SIMM programmer.
The power supply wouldn't stay on at first and I quickly realized I needed to add a load to give it something to actually power, so I used a bunch of 50W, 6 ohm power resistors.
Got a kit from Amazon with way more than I needed. I put 3 of them in parallel across the 5V output rail (2 ohms = 2.5 amps = 12.5 watts) and 4 of them in series across the 12V rail (24 ohms = 0.5 amps = 6 watts).
I haven't scoped it yet, but interestingly enough, the power supply behaves perfectly fine in my tester. It turns on with the 200 ms high pulse, and off with the 100 ms low pulse. When I turn it off, it stays off.
So now the big question is: is there something wrong with my IIsi's logic board, or is my tester inaccurate because it doesn't add all the extra capacitance onto the 5V rail that the logic board has? Maybe I should pay closer attention on the logic board to where exactly /PFW goes and look for any board damage or leakage along the way.
BTW, I think I'm pretty much done with the IIsi riser board schematic. I still need to determine the values of all the ceramic caps, measure the trimpot to make sure I have the right resistance, and try to identify a suitable replacement for the =B (mine's marking looks more like _B) diode that goes between the 12V and 12V-always-on rails.
