Glad I found this board. Hope someone point me in a useful direction to get a recently liberated Mac IIsi up and running.
Long story short: There may be multiple problems, but number one is the hard drive is not getting 12V of the 12V/5V needed for it to work. After a SCSI drive swapped in still didn't spin up, I measured the voltages and 5V to GND OK, but not OK is 12V to GND. Even measured directly in the logic board socket (without the cable adapting it to the molex-type on the drive).
So swapped the PSU (unbelievable how easy these early machines are -no tools needed!) - but it made no difference.
It had been booting OK from the floppy drive, but that just started grinding and not reading. Another thing to clean or swap.
Dust has been blown off the logic board but it still seems kind of grimy in places. Although not electronically experienced, a logical approach generally isolates problems for me - but if this is a PCB repair problem, it's beyond my tool-kit. Anything else I'll try.
Hey the IIsi listed at $3770 according to everymac - after only 20 years I expect it still can be made to work well… And I'm looking forward to using Cricket Graph as MS products no longer support patterned fills.
Thanks.
Thanks.
