Jamieson
I'm using the onboard video on my IIci and it is connected to an NEC LCD19v monitor. I don't think the LCD monitor is "multisync". The adapter I'm using is one of those cheap things with 10 dip swiches. I've found a few dip switch settings that sort of make it work and the monitor reports a vertical refresh rate of 66Hz and 640x480. Picture is stable but washed out: pixels which should be black are medium-gray. Cranking down the brightness settings on the LCD don't help; it's something in the video signal itself. When I press the "auto adjust" button the LCD, there is a brief moment when the colors look good, but then it returns to the white washed out look. Tried changing the "gamma" setting in the monitor control panel and that improved things by a small amount. Still washed out.
Just a guess, but I think the IIci video is adding sync pulses to all three colors and it's confusing the monitor's auto adjust circuit and is not properly establishing the black levels. Any suggestions?
I'm going to try building the circuit that is shown in THIS VIDEO where the guy has the IIci internal video seeming working with an external monitor.
