IIc strange image
WillJac
Ok I will get my new chips Tuesday so I will remove it and put in a socket for now and wait for the new. I also get the new memory so will do the ls32 first and if need the memory after
WillJac
Well here's to hoping!
Thanks for all your input and guidance. This how i learn and will be able to pass it along to others. Will keep you posted. If you think anything else let me know. I am retired so I am always around.
WillJac
You think good be something with the TMG chip as I have no video7M output from the chip only place I see something missing.
WillJac
Sorry vid7m from pin 13 goes to the video chip after on pin 6. I have no signal at all on 13 or 6 but on other machine as soon as I turn on, I have signal wave.
WillJac
Can’t trace more. The signal originates from tmg chip goes to IPS then the video signal. It’s a timing clock signal so if that not there I do t think the video will come up good.
Lycus
Let's see first if the 74LS fixes it, as broken RAM circuitry can cause cascading problems.
WillJac
I replaced the LS32 and 2 of the ram I found to be bad and now I get this. Any ideas?
WillJac
Ok let me get the readings and send them. So far what I am finding is EN80 is not enabled coming from MMU and also going to that LS32.
WillJac
I am going to park this for a few days work on some other stuff. My mind is fried about this logic board. I have a plus, Mac II and SE to work on.
