kkritsilas
Hi,
I have recently bought a Centris 650 (you can see what I posted on it in the Mac II/Centris/Quadra section of the board). I was also able to locate a PowerMac 7300/200. It has a broken front panel power button, which I understand is pretty common to this generation of PowerMacs due to the brittle plastics used. Without the front panel power button, is there any way to turn on the power? I am thinking power button on an ADB keyboard, opening up the case and manually pushing a button, shorting a pair of pins, or like the Centris, a power button on the back panel?
I am going to need to get inside the machine, anyway, as I have zero details about its configuration (RAM, hard drive, VRAM, etc.). The machine says it is a 7300/200 on the front panel label, but that is about the extent of what I know. I did read up on it, and the base configuration is a 32MB RAM, 2GB SCSI hard drive, and 1MB VRAM. I really don't know if it is all there or not.
I'd appreciate any assistance. I'm going to open the machine up to see what is there, and if it is all there, I'd like to power it up and see if I at least get a start up chime.
