I am now hosting TheMouse2b
coius
After finally retrieving it from google's cache, i decided to host TheMouse2b for anyone looking for it. I know some of you may have come onto my site before, but i am not meaning for this to be a plug either
TheMouse2B
it's just a tiny 97KB file that I got out of google's cache. Let me know if you guys like it. It has all the original contact info, and if you can get a hold of the guy, please pay for the software, it doesn't have any limitations, but I guess it's just "Trustware", if you like it, he trusts you to pay for it.
Anyway, that's the link. While you are there, check out the other hacks I have, like my pismo among it with the checkered keyboard.
coius
speaking of which, i need PCI Extreme badly, It suddenly fell off of the web. I kinda need it right now. Anyone got it?
Blessed Cheesemaker
I forget where it was (probably at xlr8yourmac.com) but there was a technical discussion somewhere of the reasons why you probably should *not* use PCI extreme. I think it boiled down to a theoretical discussion of using the older PCI bus to handle data transfers as well as the graphics. Anyway, if you have used it before and it works, then I probably sound like your mother...it all sounded theoretical anyway.
