How to unbox a NeXT Cube 25 years later
uniserver
Mostly a cleaver trade, nothing too crazy
http://en.wikipedia.org/wiki/Cleaver
lol
haplain
Having some boot issues right now. It starts but doesn't recognize the hard drive. It tries to load from the internal CD drive but takes FOREVER so I don't think it's working in the sense there's a MOBO issue. The CD-Drive and HD spin up so I know it's something silly
I have EVERY version of NeXT and NeXT step on disks and CD-ROM so whatever OS I install once I get her working. I just send the board out for a recap (an extra board) and think it's having a keyboard input issue. The fact I cannot use the COMMAND buttons on startup to force it into programmers mode lead me to think it just needs a servicing. I've seen an article discussing that issue and it seems to be a simple fix. Thanks Uniserver! The fact it boots, loads, HD seems to spin, CD-Drive takes a disc leads me to believe it's something silly. Good thing I've got 2 mobo's.
Anyone have any suggestions?
haplain
I have 2x 68040 25Mhz boards. They both have the aluminum caps. They didn't appear to be bad but what do I know. Obviously something isn't working and some is so a recaps a great place to start. I figure worst case I'll reach out to rob at blackhole and get a working board but really want the original one to work.
I'll probably get a laser printer in box for keepsake too ;-) why not right
CelGen
That I recall, both NeXTSTEP 2 and 3 will not directly boot off the CD unlike NeXTSTEP 1 did on MO.
You need to bootstrap the system with the included boot floppy which according to your dual MO bezel you do not have. Neither do you have a floppy drive (and NO they are not Apple's floppy drives). There are hacks however to dump the CD to a hard drive and then install to the same drive.
Go ask the forum at nextcomputers.org for additional info on this.
Also, are you trying COMMAND + ~ to get to the PROM?
haplain
That I recall, both NeXTSTEP 2 and 3 will not directly boot off the CD unlike NeXTSTEP 1 did on MO.according to your dual MO bezel you do not have. Neither do you have a floppy drive (and NO they are not Apple's floppy drives).
Sorry to disappoint but I said I had EVERYTHING :) I'll try that little trick and thanks for the suggestion
