ironborn65
When I find a Mac, I can often find data and apps in it.
Sometimes I even find personal information, emails, documents, pictures (starting from the G3/G4) ... I'm used to recover the data to send it to the owner when possible, then in any case I remove the personal information. People are not taking care of the personal data the leave in their old pcs.
At the end I am left with the software I want to preserve:
This is the procedure I use to create images to preserve software:
I boot from external SCSI2SD.
I create a non compressed image file of the entire hard drive, with Disk Copy 6.3.2 and I save it in the SD in the SCSI2SD card.
I move to modern MacOS where I retrieve the (large) SD image using dd and I copy it in a storage area.
I attach the image to BasiliskII and then I mount the original hard drive image I find inside.
I copy the disk drive image in my storage area, in this way the image is as large as the drive, not as the SD card.
Then I start creating a compressed read-only image for every Folder that contains an application that deserves to be preserved.
I finally delete the large SD card image,.
I understand this is not enough if the application has been installed, especially if extensions are present in the system folder, for this reason I tend not to delete the original hard disk image captured,
Using BlueSCSI or ZuluSCSI should be easier because I could drag&drop images without using dd.
Any advice about this procedure?
PS: in case someone thinks asking for the images I captured: I never (yet) uploaded images in Macintosh Garden, any advice are welcome on this matter as well.
thanks
thanks
