mattia1071
I'm asking someone help to install a version (italian version) of system 7.1 or 7.5.3 (7.5.5) in my PB 180 and 180c
I was able to install both verisons on a disk image using Basilisk. If I boot from that image, basilisk works.
My plan was to use HDI25 port to connect bluescsi + SD with that (see above) disk image and simply copy the system folder from that image to on the internal PB180 drive. Then use system picker to boot from the new system folder.
My question is: is this going to work?
In fact whet bluescsi is connected to the PB180, the PB try to boot from the bluescsi (WHY???!!!) and doesn't work (WHY!!!) On the bluescsi drive I have 7.5.5 wich doesn't require enabler?
second quesiton: How can I manage to use a .toast image to install 7.5.3 (7.5.5) system on PB180 using bluescsi?
I used this .toast image to succesfully install 7.5.3 (7.5.5 update) on a blank image using basilisk. If I ount toats image on PB180, then the install procedure do notwork..
I also tried to use floppy images but no way...
Any idea? My goal is to use bluescsi to install a new system 7.1 with 131 enabler or 7.5.3 (7.5.5) on my PB180 and 180c.
