Hi, How can you ID which is ATA Bus 0 ? Terminal? Open Firmware? Disk Utility? Look for label on logic board connectors? Other?
Detail:
After the "Ultra ATA-100" bus started failing years back (with errors), moved the HDDs to the two Ultra ATA/66 bays.
Never had occasion until now to start in FireWire Target disk mode. And it won't work (just powers down).
When searching, keep finding a line "Make sure the target computer has an ATA hard drive on ATA bus 0."
Hmmm. Simplest explanation might be that the ATA-66 isn't Bus 0... But darned if I know how to tell.
Profiler simply says "ATA Bus". Disk Utility doesn't have an explicit label for it in the info window. For the 2 HDDs just get:
Disk Identifier : disk0 (or disk1)
Connection Bus : ATA
Connection Type : Internal
Connection ID : Device 1 (or Device 0)
Device Tree : mac-io/ata-4@1f000/@1:0 (or @0:0)
Is it "encoded" in the Device Tree? The first @1 ??
Not open firmware savvy, but when tried to boot from there using "target-mode" command got:
can't open disk
can't find any units
TARGET-MODE unit failed
Thanks for any info.
Detail:
can't open disk
