Hotline Server for Linux
pfuentes69
Hello,
I'm building a Hotline server (for the fun, basically). I managed to have one operational already using Mobius (hotline.retrobyt.es, it's in hltracker.com). Mobius seems to work well but I'm having issues with the integrity of uploads and downloads.
Does anyone know of another solution that can run on a modern Linux. I tried several options I found and I can't compile the source code to build it.
Txs
pfuentes69
So the creator of the project is really active to support and helped with a patch to solve a minor issue
Halcyon
Hi, author of Mobius here. 👋
Since this post I've fixed a bunch of issues and added support for preservation of resources forks on files uploaded from classic Macs to Linux/Windows/OS X. I've also added brew packages and a Docker image, so it's never been easier to run a Hotline server on modern OSes!
pfuentes69
Thanks!
I’ll update my server ASAP
Halcyon
The resource fork support is off by default because there are some implications to understand, but if you're interested in enabling this option check out:
Cheers!
pfuentes69
It's been a while since I couldn't go back to this... today I installed the latest version and I just came to say again thanks to @Halcyon !
