Little orange monster version 1.1, now with LC 475 guts, a PDS ethernet card, and a speaker. Here it is outfit with a Floppy Emu and ADB-USB Wombat:
I realized I mounted one of the side pieces upside down yesterday, which explains why things seemed a little warped. It's better now.
After removing the metal shield from the ethernet card, there's just
barely enough interior height to fit the card, the shelf, and the SCSI2SD above it. Using a SCSI cable with integrated strain relief, it wouldn't fit, and I had to substitute a different SCSI cable that's a couple of mm thinner. Rotating SCSI2SD 180 degrees with the component side up was impossible.
The case opening for the PDS card is fine, but without the metal shield, there's a gap around the ethernet jack. Bonus ventilation! Here's a photo of that, along with the right side vents:
The speaker is taped to the inside of the case to prevent it from moving around, which is ugly. There's not enough space for it to lie flat, so it's propped up at a strange angle. I'll hunt around for a smaller 16 ohm speaker to use in its place.
There's a slot in the front where I've run a floppy ribbon cable, so I can hook up a Floppy Emu when needed.
The LC 475 version runs cooler than the LC III did (which was already fairly cool). I'll find some proper feet later, but for now I've propped up the case to provide some passive airflow to the underside vents. Even with no fan, I couldn't find anything inside warmer than 88 F / 31 C. I was prepared to mount a tiny fan inside, but that doesn't look necessary now since the passive cooling is more than adequate.
So I think this little guy is pretty much done, aside from feet and maybe a new speaker! It's barely any bigger than my keyboard, which is neat.
If anybody wants to build their own, or use this as a starting point for further experiments, take the files I posted here:
https://68kmla.org/forums/index.php?/topic/30772-homemade-mini-case-for-lc-p475-q605/?p=334916. There are two files: one for the bottom and sides, and one for the top and shelf, so you can have the two different sheets made in different colors. Upload the files to ponoko.com, and have each one cut on a P2 sized 3mm thick acrylic of your color choice. You can also use 3mm MDF wood if you want a different look. Along with the case pieces, you'll need 11 M3x10mm screws with matching nuts. #4-40 size screws probably fit too, but I haven't tried it. You'll also want some plastic zip ties to strap down the power supply.
A few things I'd do differently, if I were going to do this again:
- Add about 3mm to the height under the shelf, to fit thicker PDS cards
- Add about 3mm to the height above the shelf, to fit thicker SCSI cables
- Integrate small feet into the side pieces, to elevate the case for better underside airflow
- Have fewer vents around the PSU, and more vents around the CPU and PDS card
- Cut the vent slots into the shape of an Apple logo
- Reposition the floppy cable slot, so it's better aligned with the logic board's floppy connector
- Add an opening for a power LED so I can tell when it's on
