Hello All,
I figured I'd make a quick how-to for my own reference and to make this a little easier for folks who may want to emulate a powermac on Linux. This will be a step-by-step for each distribution, starting with Arch because I use it daily. This will be a WIP where I add sections for each distribution.
Code blocks like this one will be used to indicate when a section of the guide should be input on the command line.
Things You'll Need | Link |
MacOS 9.2.2 CD-ROM Image |
Arch Linux
Arch is renown for being the Linux distribution where user choice matters a lot. These instructions are specific to how I use it and there are many different ways of accomplishing the same thing. These instructions also assume that you have a working x11 environment and that you are using or can use systemd-networkd. It is optional to setup and use sudo on Arch, though I highly recommend that you do. I will preface each command with sudo that requires superuser privileges.Install Required Packages
