ima
Hey everyone,
I am trying to analyse what's up with my iMac G3 that quite often has green tint to the all the colours especially after being turned off for a while. When this happens it looks like none of the colours (R, G or B) are missing but they are rather washed out with green.
It is especially noticable in full screen games (640x480) with dark background where blacks become green.
On desktop in MacOS 9 and OSX it is less noticable however I noticed that amount of green tint depends on the amount of white currently displayed on the screen. If I open a Finder window and make it large all colours go back to normal (blacks look black etc). If I move the window to the corner or close it - i instantly see a change of all colours to have a green tint again.
Very often, after some time of the G3 being on, the colours go back to normal permanently until I turn it off and not use for a while.
I tried the following:
I do not have an external VGA socket on this G3's logic board unfortunately.
The CRT tube definitely works well cause this green issue came after I installed the analogue boards together with the logic board from another G3 (whose CRT tube was VERY bad).
The reason I did the swap of components is because in the current G3 its logic board had dead VRAM (artifacts). I also suspected that the its original analogue board (before the swap) was not working 100% since I had 2 (!) logic board's VRAM die on me within 2 days. So I replaced logic board and analogue boards.
Unforunately, I do not have access original logic board (and another one where VRAM died too) because I had already (rushed it) removed the VRAM from them while waiting on new one in the mail (from Alixexpress which is taking while to be delivered) so I cant check if it is the logic board's video chip causes the green tint or not.
What I can do though, is put back the original analogue board (the big one that connects to the neck of the CRT) and see if that removes the greeness. It is just very annoying and long to disassemble and assemble the G3. And I also worried it will kill my third logic board's VRAM.
Anyway, I thought I I would share my journey here as well maybe try my luck with suggestions from other readers.
I've published two videos on YT to show what I mean with green:
MacOS 9 desktop colour change when moving window (look at top task bar colour) -
Monkey Island green background -
Hey everyone,
- PRAM reset
- Open my G3 and knock things around especially in the neck (I do know how to be careful with CRTs before you ask)
- Froze (with freezer spray) most components on logic and analogue boards (both small and large inside the CRT) and CRT neck
