just.in.time
Okay, so here's where I'm at:
I was given a Newton 2x00 DVT model (not sure which one exactly, it has the DVT tags from testing prior to regular production I believe). Battery was shot, so I rebuilt it. I also have what I think is an older Newton charger, but it work fine, and a 2mb memory expansion in one of the PCMCIA slots. This all actually occured ~2 years ago, but life has been hectic so I have basically just been charging the unit back up every few months when the battery is low/dead.
What I don't have is a serial cable to connect the Newton to any of my Macs, BUT it does look like it has an IR port, which my PowerBook 2400c running Mac OS 9.1 also has.
All that said, is it possible to use the PowerBook to load software to the Newton using the IR blaster? If so, what software do I need on my PowerBook?
Once that is all set up, what is some software that I should put on the Newton? Any system patches, games, etc?
