GondolinOnMyMind
I just got this one. Excitedly set it up and turned power on. Aaand it won't boot.
Symptoms
What have I done:
I should add that the very first boots did not succeed at all; the fans twitched and then kept still. I removed the simms (those were on #4-slots) and moved to #1 slots, reattached the display adapter. At some point those actions (or the matter that the computer got fed enough power as it had been without power for a couple of years) helped and I was faced with the symptoms above.
Any help is appreciated. This is a beautiful computer and I would love to get it running.
Symptoms
- power led is lit when button is pressed, it goes off right after
- fans do rotate slowlishly.
- fans do rotate at full speed when the plastic cover is removed. Also a red led is lit on the logic board. Both go back to normal when cover is put back
- no chime
- no picture
- There is no pram battery
- 2 Simms on #1-slots
- display adapter (radeon 9600) on the agp-bus
- no other leds are lit on the logic board
- computer is relatively dust free
- power goes off when power button is kept pressed ~10 seconds
What have I done:
- reseated memory and display adapter
- booted several times with various configurations of no memory installed, with memory, no display adapter installed, with display adapter
- also tried with and without a hard disk. I do not have a hdd sled.
