G4 7455 or 7457 CPUs needed
Nixontheknight
I have a 1.25GHz MDD dual CPU card from a rev a MDD from 2002 that I blew up due to over voltage. Does anyone have any spare 7455s or 7457s I can use to put on the card? Thanks in advance
alectrona2988
Unfortunately these are the only ones on eBay present at the moment, preballed at that. You may have also fried something with the VRM and such, too. I'm in the same boat as I may have damaged a component on a dual 1GHz QuickSilver card. Ervus on MR or herd may be able to help you out with card repairs. Fairly certain there are also underlying problems with your 1.25 card as well; I had 2 MDD dual cards die on me once, without any mods made.
