Floppy drives
MultiFinder
The floppy drive in my 6500 seems to have something wrong with it. Either that, or every single floppy in my room has some problems :p
How would I go about diagnosing what's wrong with my drive and possible fixing it?
On one last thing, can the floppy drive from a compact (the auto-inject) be used in the 6500?
Danke!
:beige:
MacTCP
I've gotten floppy drives to work better by vacuuming them.
tomlee59
Try formatting a floppy in the suspect drive. If it formats successfully, and you can read from and write to that floppy, then the drive is basically ok, but needs alignment.
If it can't even format its own floppy, then it could be dirty, or has a loose cable or ...
Since it's easy to clean the heads, do that first and retest. If that doesn't fix it, open it up and do a more thorough clean of the mechanism, check cables, etc.
And yes, electrically the auto- and manual-inject versions are compatible. Mechanically, there are minor differences that may require a little modding.
The Macster
I once tried putting a manual-inject one in an LC as I have a dead auto-injecter and a spare manual one, and the slots didn't line up so it was no good, so you'll need to check whether it all lines up correctly in the 6500's case.
