Iesca
After a diskette completely jammed in the floppy drive, I was forced to pry it out with pliers. Unfortunately, such a procedure is far from delicate, and the top drive head was damaged and put out of place. (Actually, I managed to damage the head before even attempting the pliers; they were simply a last resort..) Attached are photos of its current state.
Shoulda-woulda-coulda, the deed is done; is it repairable, or is it time for a replacement?
I should say, the drive was never ejecting properly in the first place, even after cleaning and relubricating, as well as replacing the drive motor gear. I would get the disk inserting and ejecting seemingly fine when out of the machine, but the moment I fastened it in its bracket and installed in the Mac, the drive would never eject on its own without helping it with tweezers or similar. Then it just jammed up. :\
Thank you!
Thank you!
