Tom2112
OK, I've read several threads about flashing PCI SATA cards - here on 68kmla and other forums - for use in G4's (and others)... I always leave the thread confused. So I got frustrated and decided to throw money at the "problem" and bought one of those $50 pre-flashed Sil3114 cards on eBay. Of course, it didn't work in either my G4 Sawtooth or my G4 Quicksilver - apparently there's a know issue with those models. <sigh>
So I was poking around and trying to figure out which card to buy and try flashing it myself... and I picked up a Sil3112 (not the best card, but they can be found cheap).
Now, I'm no dummy - though I've done my share of dumb things - but I digress... I've flashed the firmware on many devices. It's not hard. The hardest part is finding the right firmware file to write to the device and the right tool to do the flashing. Once you have both of those things, it's usually as easy as riding a bicycle.
Can anyone tell me:
Thanks in advance,
Tom
Can anyone tell me:
- Will the Sil3112 work in a Sawtooth or Quicksilver?
- If it will work, where can I find the firmware and flash util?
- If no to both, then can you tell me which card will work (one that is obtainable) and how to flash it so I can boot a Quicksilver from it?
Thanks in advance,
Tom
