3lectr1cPPC
I had just installed both Mac OS 8.6 and OS X 10.2 on my iBook Clamshell, and then I discovered something. While OS X could switch the startup disk to the OS 8.6 system folder, OS 8.6 could not switch the startup disk back to OS X. I was about to write up a thread asking if there was some 3rd party tool that could switch system folders, but then I had a thought. What if I just copied the Startup Disk control panel from a copy of OS 9.2.2 and replaced the OS 8 version. Would it work? I had to find out.
It did!
I’m not sure how far back this works, but there you go!
For all I know, this could be common knowledge, but I thought I'd put it here in case it helps someone out in the future.
It did!
