Does anyone need the Apple Network Server 500/700 Diagnostic Information, Utilities, and Documentation I have?
jajan547
I have the following:
  • ANS 500/700 User Manual
  • ANS 500/700 Using PCI RAID Card
  • ANS 500/700 Using AIX and ATalk
  • ANS 500/700 Parts List
  • ANS 500/700 Service/Repair Guide
  • ANS 500/700 Diagnostic Utility (Floppy for diagnosing issues and running tests)
joshc
I don't 'need' them but I know we do have a few ANS owners on the forum so I'm sure they'd appreciate these. Probably worth uploading to archive.org if they're not on there already.
jajan547
All of my discs are not archived I have the following:
  • Apple Service Technical Support Information Source April 1990 (NOT the DEMO on Macintosh Repository or Macintosh Garden, The full release)
  • Apple Service Source April 1993
  • Apple Service Source 2.0 December 1996
  • Apple Service Source Companion December 1996
joshc
What machines have you got? ‘dd’ to an iso should do the trick to make a perfect copy including the file system/partition map on the discs.
jajan547
Well I have a 2017 iMac, and basically everything 1980-1996 that’s about it. If I got the USB disc thingy that Apple sells would it work? If not would a better solution be a cheap iBook?
MrFahrenheit
Do your 1990's Macs have a CD-ROM drive? You could easily download Astarte CD-Copy 2.x from Macintosh Garden, launch it, insert a CD, and save the image out as an ISO. Then just upload that ISO to Macintosh Garden.
I'd love to see what's on these CDs.
jajan547
I suppose I could do this on my TAM or 6360. I also have a SuperDrive but it doesn’t like to read these older disc images.
ScutBoy
I have a couple of these docs, but wouldn't mind collecting the whole set. Will wait patiently :)
jajan547
These are what I have and wow looks like Apple dropped CD-ROM support in Ventura. I will have to make a new IDE2SD image for my 6360 albeit it's the prototype so not sure how picky it'll be with other OS's but I think it'll be okay on Mac OS 8. Anyways I can't do much until I make a new bootable image but like I said here's some of what I have lying around.
joshc
What makes you think this? CD support is still there in Ventura. Apple still sells their USB SuperDrive and Ventura still recognises other brands of USB CD drives.
What have you tried to get it working?
Those CD-ROMs will have HFS partitions so modern macOS can't mount them. But using hfsutils or fusehfs would work.
Otherwise, just insert the CD, and then use dd to copy the image contents to a file and distribute that. That will preserve the data and partition map of those discs so it would be the best way to archive them.
Realitystorm
I will have to check, I think I got some of these in the bin of disks with the NewLife haul. I just used imgburn on my Windows PC to make a .bin file. I find I can't make working copies of bootable Apple HFS CDs using the ISO standard. Haven't gotten around to investigating
