blindowl
TL;DR
My Apple II Plus goes straight to the basic prompt instead of spinning up the Disk II drive in wait of a floppy. The drive is just quiet and does nothing. I got it working for a short period of time, but then it died again. It has power though. Where should I start my troubleshooting?
Long version
I just picked up my first Apple II (Plus) the other day and now I'm going thru everything, step by step. The first problem I had to tackle were some keyboard issues. But after re-soldering and changing a few switches all keys worked.
My next problem was the Disk II drive. It didn't start at all when I tried it the first time. I took it apart, inspected all components, cleaned it a bit and re-attached all connectors. After which it came to life. I could load a few programs from floppy and all seemed good. Then the keyboard started to behave weird again, typing wrong characters and after some time no characters at all... I decided to put the computer away for the day.
The following day I managed to fix the keyboard problem by re-seating and cleaning the chip at position A3. After a few reboots everything was normal again. Time to try some more floppies. And now the Disk II was dead again...
So what happens when I turn on the computer is it goes straight to the basic prompt. It does not wait for the drive. The drive does not spin and the head doesn't re-calibrate. I've measured the voltages on the drive connector and they seem ok. I can see the drive LED flash slghtly when the computer is turned on and when turned off.
Where should I start troubleshooting? Can it be the controller card? I've tried it in both slot 3 and 6. If I try the "PR#6" command the cursor disappear and then nothing more happens.
I should also add that I downloaded a diagnostic disk and converted it to audio (using the c2t tool) and after loading for 10-15 seconds it goes to some "INSTA-DISK" screen, the disk drive spins up for a few seconds (while making some noise, not the normal head calibration noise), then gives a "DISK ERROR". So it shows the computer has some control over the drive.
Long version
