GaiusIuliusCaesar
I am working on getting a RaSCSI setup for using the Raspberry PI Compute Module 4. I have the I/O board and 1GB ram CM4 Lite(no onboard EMMC). I wanted to use a 2GB or 4GB version but they are out of stock at work due to chip shortage(I am a repair tech at Microcenter). Anyway, the whole reason is I am trying to get it to run from a NVMe SSD, since the CM I/O board has a PCIe 1x slot. Yes it is only PCIe 2.0 and only 1x but should still out perform any SD card in both speed and longevity. I had to order the NVMe adapter from Amazon due to the fact that I only had a 4x adapter.
Pic of the case I am working below in Fusion360. It's is current in the "did I measure and cut the holes in the right place" phase.
Anyway the real question here is this, is there a way to +5 volts OLEDs working on RaSCSI hat? The reason I ask is have a couple of screens from a project for a fast floppy gotek in my Amiga.
Also any other suggestions or ideas are welcome
Thanks
Thanks
