brayne
Hi all,
The other day I bought a non-working Mac Classic off eBay, and it arrived yesterday. All I wanted was the case, so I didn't mind that it wasn't working.
I opened it up and found that the little 3.6v PRAM battery had corroded and had leaked acid all over the motherboard. When I pulled out the motherboard, the battery and holder fell off, followed by a few resistors and ICs. The printed circuit board itself is absolutely cactus.
Anyhow, I just thought I'd mention this as a warning for all those folks who are storing old Macs in their sheds/cupboards/shelves. Make sure you regularly check (or remove) the PRAM battery, otherwise you might pull it out to use it one day and find that it is completely stuffed!
brayne
brayne
