CUDA, EGRET, HC6805 Hacking
pb3623
I'll throw this out there even though I'm not 100% positive it's still relevant:
I would be willing to at least loan out my nonfunctional Q700 board (the one that spawned this thread) or would outright donate it to science to help further this cause. It's not doing anything for me right now and may never work. It (and I!) would benefit if there's even a hint of what caused the ADB issue I'm having. PM me if there is any interest.
Dandu
Is this possible tu dump and recreate a CUDA Lite chip ?
It would be fun to add PS/2 Mouse and Keyboard on a Mac.
I thunk it's the same chip, but with more memory and code inside the firmware to handle PS/2 peripherals.
On the Mac side, the Power Mac 4400 use this chip, but without the component to use PS/2 (the trace are on the motherboard)
powermax
Never heard anything about it. Can you supply some more information on that CUDA Lite chip?
Well, CUDA as well as its predecessors (Bit-bang, Egret) is basically a multipurpose MCU that emulates some peripheral bus protocol using the bit banging approach. In other words, all required functionality is implemented in software.
To recreate the chip, we thus need to download and understand its firmware.
IIRC, Arbee from MAME project may have already obtained a dump of CUDA Lite as he did for other CUDA versions. I'm going to ask him...
powermax
Hi crews,
I've just started uploading a commented assembly for the Cuda Firmware v2.37, see this Github repository. To my knowledge, that's the latest firmware available but we need to re-check it. In the next days, I'm going to put even more docs on Cuda - so stay tuned!
bigmessowires
Thanks for the commented disassembly! Is that the whole thing, or just a part? I didn't see anything in there for how CUDA monitors the power button and asserts or de-asserts /PFW to turn on/off the power supply.
joshc
Did anyone manage to dump the contents of an Egret? My understanding is that it's got custom Apple ROM contents to handle RTC/ADB.
My understanding of how most of this works is limited beyond "there's stuff on a chip there and we want to grab that and program a replacement chip", so what are the main blockers to achieiving this?
