Clone / backup utilities
hunter44102
Is there a utility (for compact macs) to clone an entire hard drive from the internal drive to external SCSI ?  Or to a file
I have a floppy emu. It says it can handle up to 2GB raw disk images.   How would I make my own blank 500MB raw image to back up to?  (or custom size for the drive I am backing up)
avadondragon
You can use Apple's Disk Copy.
From menu bar select:  Image > Create New Image...
Set the size however large you want (up to 2GB I think).  The images should work on your floppy emu as this is likely the file type it expects.
