ClassicHasClass
As posted to macos9:
Classilla 9.2.3 is released, after a long (and partially unexpected) hiatus.Like 9.2.2, this is a bugfix release, but there are several important fixes.
Chief amongst them is a mitigation for recurrent crashes with certain
JavaScript DOM manipulations. This should significantly improve the stability
of the browser at the cost of some additional memory usage during complex
layouts.
This version also blacklists DigiNotar certificates to protect the user, and
has fresh SSL roots. It has also been audited for the Rizzo-Duong SSL attack.
Finally, there is a performance adjustment to use a faster method of time
computation. This code is run very frequently in the browser, so this should
make overall operation more smooth.
There are some other miscellaneous fixes. You can get it, as always, from
http://www.classilla.org/
Starting in 9.3.0, we will start the transformation towards encouraging
mobile content. More about that soon.
