Classic - Mac SE HDFD: CRT swap?
ironborn65
Hi mates,
I have a cracked CRT of a Mac SE HDFD and a spare one from a Classic.
Can I replace the Mac SE CRT with the one from the Classic?
The resolution is the same but ...
Are the pins of the joke compatibile/equivalent?
Can I keep the coils or should I move the ones from the Se CRT to the Classic one?
"to be or not to be?"
thanks
Zitruskeks
ironborn65
sure, thanks for pointing this out, the moderator will decide what to do ... have we a moderator?
Anyhow, the broken CRT from the SE is a Clinton as the Classic and both have the same exact model number, there is small difference in the serial number: they are very close to each other.
The CRT from the Classic comes from the rev B board and from the thread it should not be compatible with the SE:
Still the plug for the CRT coils are the same,.
In the Classic the wires of the joke are soldered to the board, while the SE has a nice plug.
So, I'm tempted to simply swap the CRT, the only check I'll do first is to verify that the two small board in the CRT have the same circuit.
Any one can share their experience?
PF
joshc
The CRTs are swappable. It’s the yoke connector that can differ on Classics depending on the revision of the analog board but using that CRT with an SE is fine.
