Classic II – won't start after cleaning
3lectr1cPPC
Huh? The classic II doesn’t need a battery to start. That’s systems like the Mac II big box series and the 475 series macs
blindowl
Since my last post I've put this project aside for the moment.
Summery of what I've done:
• Replaced all caps on the logic board
• Adjusted the voltage rails on the analog board
• Changed to another pair of RAM modules — computer now actually started to boot normally, but with intermittent issues. I SHOULD’VE STOPPED HERE!
• Soaked the logic board in vinegar and rinsed with water — BAD IDEA! Now it didn’t start at all... (the start of this thread).
• Soaked the logic board in vinegar again, rinsed with IPA.
• Replaced a missing/damaged micro cap on the back of the logic board
• Removed and cleaned the Egret chip — computer started again! PHEEEW
• Replaced several caps on the analog board
• Re-adjusted the voltage rails
• Replaced the onboard RAM chips — twice!
• Replaced all capacitors (except 2 × 1 uF) on the logic board — again! Better soldering job this time
Issue is virtually the same. Just another pattern on the screen (after the swapped RAM chips I guess). Pattern is less garbled, though.
One day I will remove and clean the Egret chip again. Then I'm out of ideas. I've beeped the most obvious components and traces with the multimeter, and everything has been normal.
