PB170
Anyone up for some reverse engineering?
As some of you may know, I'm using my PowerBook 170 more or less daily (last time I checked, my usage clocked in at 4 h 18 min / day over the past year and a half which probably is more than I spend on my MacBook and phone combined
Anyway, being the standard text editor on classic Mac OS, I often open smaller text documents in SimpleText (version 1.4). However, since all documents open to the default window size, which covers most of the screen, and I usually work with multiple documents, I constantly find myself resizing windows on open. It has now come to a point where I *really* wish I could modify the default window size with ResEdit
Unfortunately, I'm not really up to the task myself.
So, anyone who would be interested in helping me out?
As a starting point, the code appears to work like this (tested on multiple systems and monitor resolutions):
- The top left spacing is always 4, 40 px
- The bottom spacing is always 34 px
- If the display resolution is wide enough (actual threshold unknown), the window opens to 600 px wide, if not it opens with 80 px spacing to the right
