CC powerup
waynestewart
One of my Color Classics had some powerup issues. Tried a different Logic board but that wasn’t it so I decided to recap the analog board. I didn’t have all the parts but decided to replace what I had while waiting for the rest to arrive. Since there were a number of the same caps used I desoldered all of each and replaced those then go to the next.
Once I had those done I thought I’d reinstall the analog board and see if that solved the problem. Once it was together I pressed the power button and nothing. I checked to make sure I hadn’t missed connecting any cables and tried a different keyboard. It was late so I went to bed thinking I’d destroyed a Color Classic.
The next day an idea came to me so as soon as I got home I took out the Analog board and held it up to a light. There starring at me were 2 holes ¼ inch apart. I’d missed putting back a capacitor. Five minutes later it was assembled again and started up as soon as I pressed the power key. The parts I replaced seemed to have solved my powerup problems but when the other caps arrive I’ll replace those so I know I have all new caps.
joshc
Yeah, it's always worth double checking your work, and referring to a diagram/photo of the board so you know you haven't missed any capacitors.
For the effort it takes to remove the analog board from one of those, I would've ordered all the capacitors beforehand and waited for them to all arrive and just tackle them all in one go.
Glad your CC is working again now.
waynestewart
The Color Classic analog board is pretty easy to remove. Unplug 6 connectors and it slides out.
The online guides suggest replacing just 13 caps but there are almost 50 and I’d prefer replacing all of them.
I thought about waiting until I had all the caps but I realized that I just don’t have time to do it in one go. I get home pretty late so most likely over 3 evenings.
